G
I am getting very close to D-Day when I will crank the engine after the BIG OVERHAUL. Dilemma, I have a new radiator, new water pump housing, new hoses and new heater core - all dry. The only coolant in my system is the little bit left in the water jacket in the block. Filling from the radiator will not get coolant to the pump, especially with a thermostat cold and closed. I thought of temporarily pulling the thrermostat and somehow pressure filling the whole cooling system so the the water pump will have something to pump. Simply filling the radiator and expecting the fluid to flow doesn't seem likely to me. Or will the coolant, if filled just from the radiator cap, reach the water pump naturally? Should I pop the thermostat anyway when doing a static fill and then glue it back down? Am I missing the point here? Surely I must open the heater valve during the whole process (my new heater is soooo pretty....). Any suggestions? Oh, and Happy Thanksgiving to everyone.
Bill
Bill
