Hi Guest!
Yes, great for appearance, but I suppose the intended use of the car should also play a factor.richch said:We always finish the insides of the panels and the inner wheel arches, everything as clean and smooth as the outsides, which makes for an easy surface to keep clean. Today's paints are easily durable enough to not be blasted off. Any rough surface will tend to allow dirt and crap to cling and be difficult to keep clean.
COvering my bases. Since 99% of the cars I work on are shipped to me, any sort of "comeback" is unacceptable; I cannot let anything slip by. Whenever I have to do a task with a portion unfinished, I leave myself a reminder that can't be missed (tape across the driver's door opening is also popular around here). I used to use a China-Marker, and write notes on the windshield__in front of the driver__couldn't miss it, but removing and throwing away the tape was easier than cleaning the glass :wink:Legal Bill said:Randy,
Something tells me your hub nut isn't tight.
