Odd thing. The very forward part of my left front fender seam began to peel back! Don't know why. I figure there has been a failure of the rib into the seam. It also broke off right under the rubber beehive mount. Odd.
So, I decided I'd try to fully clean the area up and EPOXY it back down. What else could I reasonably do (without turning this into something big)? I used a very high-strength clear epoxy and clamped it back down... and then did a little paint touch-up. I sure hope this holds (otherwise maybe I can rivet it down under the rubber mounting). Ugh.
Hi Guest!
