The luggage rack mounted on the trunk was fastened with oval headed phillips screws that went into what appear to be swaged in place threaded inserts. The forward two are visible but the rear two are not due to trunk deck having an outer skin and and inner skin forming the rear deck lid edge.
One of them now turns and I had to drill out the screw to remove the rack.
Are these type swageable threaded inserts available anywhere?
If these type threaded inserts are not available, what is used to mount the luggage rack to the trunk (boot) deck?
The rack is the same in appearance as one in the Moss catalog.
Thanks
Thanks
