jlaird
This is only exhaust system but look at what is happening, when I get it finished we are going to be able to by fastners by the box for rebuilding or restoreing.
I am planning on doing each page in the Bugeye (IPB) illistrated parts breakdown. Will try to do a page or so a day then compile the whole works so we have a place to start. /ubbthreads/images/graemlins/cool.gif This actually looks much nicer on an excel spread sheet.
Exhaust System, Bugeye, Page A17
Item # Description AH Part Moss Part Qty per Finish Dia. Length Illus #
# # Veh.
3 Bolt Clamp HZS0518 None 2 Zinc 5/16 1 3
4 Washer for clamp bolt 2K5806 None 4 5/16 4
5 Nut for clamp bolt AHH5171 None 2 4
8 Screw, clip to bracket HZS0506 None 2 Zinc 5/16 3/4 8
9 Washer for screw (plain) PWZ105 None 4 Zinc 5/16 9
10 Washer for screw (spring) LWZ205 None 2 Zinc 5/16 10
11 Nut for screw FZN105 2 Zinc 5/16 11
12 Screw, clip to pipe HZS0508 1 Zinc 5/16 1 12
13 Washer for screw (spring) LWZ205 1 Zinc 5/16 13
14 Nut for screw FNZ205 1 Zinc 5/16 14
15 Bolt-clip to pipe HZS0407 1 Zinc 1/4 7/8 15
17 Washer for clip bolt (spring) LWZ204 1 Zinc 1/4 17
18 Nut for clip bolt FNZ104 1 Zinc 1/4 18
20 Bolt-pipe to clip to mounting HZS0505 1 Zinc 5/16 5/8 20
21 Washer for clip bolt (spring) LWZ205 1 Zinc 5/16 21
22 Nut for clip bolt FNZ105 1 Zinc 5/16 22
23 Screw for mounting to cross member HZS0505 2 Zinc 5/16 5/8 23
24 Washer for mounting screw spring) LWZ205 2 Zinc 5/16 24
28 Screw fixing clip HZS0507 1 Zinc 1/4 7/8 28
29 Nut for screw FNZ105 1 Zinc 1/4 29
30 Washer for nut LWZ205 1 Zinc 1/4 30
32 Washer for rubber bushes PWZ205 1 Zinc 5/16 32
33 Locknut for rubber bushes LNZ205 1 Zinc 5/16 33
# # Veh.
