Fastner info
jlaird
This is only exhaust system but look at what is happening, when I get it finished we are going to be able to by fastners by the box for rebuilding or restoreing.
I am planning on doing each page in the Bugeye (IPB) illistrated parts breakdown. Will try to do a page or so a day then compile the whole works so we have a place to start. /ubbthreads/images/graemlins/cool.gif This actually looks much nicer on an excel spread sheet.
Exhaust System, Bugeye, Page A17
Item # Description AH Part Moss Part Qty per Finish Dia. Length Illus #
# # Veh.
3 Bolt Clamp HZS0518 None 2 Zinc 5/16 1 3
4 Washer for clamp bolt 2K5806 None 4 5/16 4
5 Nut for clamp bolt AHH5171 None 2 4
8 Screw, clip to bracket HZS0506 None 2 Zinc 5/16 3/4 8
9 Washer for screw (plain) PWZ105 None 4 Zinc 5/16 9
10 Washer for screw (spring) LWZ205 None 2 Zinc 5/16 10
11 Nut for screw FZN105 2 Zinc 5/16 11
12 Screw, clip to pipe HZS0508 1 Zinc 5/16 1 12
13 Washer for screw (spring) LWZ205 1 Zinc 5/16 13
14 Nut for screw FNZ205 1 Zinc 5/16 14
15 Bolt-clip to pipe HZS0407 1 Zinc 1/4 7/8 15
17 Washer for clip bolt (spring) LWZ204 1 Zinc 1/4 17
18 Nut for clip bolt FNZ104 1 Zinc 1/4 18
20 Bolt-pipe to clip to mounting HZS0505 1 Zinc 5/16 5/8 20
21 Washer for clip bolt (spring) LWZ205 1 Zinc 5/16 21
22 Nut for clip bolt FNZ105 1 Zinc 5/16 22
23 Screw for mounting to cross member HZS0505 2 Zinc 5/16 5/8 23
24 Washer for mounting screw spring) LWZ205 2 Zinc 5/16 24
28 Screw fixing clip HZS0507 1 Zinc 1/4 7/8 28
29 Nut for screw FNZ105 1 Zinc 1/4 29
30 Washer for nut LWZ205 1 Zinc 1/4 30
32 Washer for rubber bushes PWZ205 1 Zinc 5/16 32
33 Locknut for rubber bushes LNZ205 1 Zinc 5/16 33
I think when I get this finished I will be able to tell you what sizes of fastners to buy by the box from our friend here on the forum.
Oh boy, all new fastners would be so nice, also will be able to tell which ones in the engine room should be stainless or chrome for fun and games.
Will stay away from the special bolts ie hardned best to get them from moss or vb I supose.
Good work compiling this, Jack. It will be a great resource once it's all together.
