Fan Blade Failure
Bill Young
I wrote an article for the Technical Service Bulletin in the Healey Marque magazine August issue on the Healey cooling system. In this article I mentioned using 6 blade fans typical of the original "Tropical Fan". I have received several comments from readers concerning these fans and others failing with blades breaking off. This seems to be a problem and a safety issue. I would like to write a followup article on fans and fan failures, and I am asking the Forum for input that members may have had with fan failures. What type of fan failed? What damage was done? What is the best fan to use? Do you have any pictures? Post on the forum.. however, you can also email me at healeytsb@gmail.com
Bill Young, BJ8, BN2, AN5
Columnist, Healey Marque Magazine
St. Johns Austin-Healey Club
Jacksonville, Florida
sjahc.com
Michael Oritt
Bill--
I have no first-hand knowledge of fan failure except for seeing opn another person's car the results of a blade coming loose and going through a shroud--not a pretty sight!
I am working from memory but i seem to recall that the failure was happening to fans where the blades were attached with only two rivets, whereas some of the aftermarket versions had three rivets in a triangular pattern and these did not fail.
Perhaps someone else will chime in with their experience or knowledge.
RonR
Several years ago, Moss use to offer the yellow "tropical" fan, but recalled it due to disengagement of blades.
Perhaps some of the failures being reported are from that production run. If so, then it is possible the reported failures are old news, or some people did not replace the Moss fans and are now experience failures of recalled parts.
B
Bill Young
Check this out. Best not be using one of these "old" fans
sjahc.com
BJ8Healeys
I was driving home from work when my fan blade parted company with the hub. I had installed a Moss 6-blade metal fan on my BJ8 on 3 May 1995 (31,590 miles showing on the odometer). On 16 January 1996 (34,103 miles), there was a sudden and severe vibration. I switched the engine off to investigate. I found a blade had failed and put a 2-inch gash in the radiator header tank. Perhaps the reason that it didn't go through the bonnet was my home-made radiator shroud riveted and screwed to the radiator fan guard and riveted to the side frame of the radiator. The blade knocked the fan guard off the tank, but the shroud remained attached at the sides of the radiator. I had to cut the fan belt to drive the remaining couple of miles home. On further investigation, I found TWO blades missing, not just one. I found the other blade the next day on the ground where I had stopped. I noted that the Moss fan was stamped "made in China".
There was a semicircular cutout at the root of each blade where the two blades had broken off. There were paint chips in some of the other blade cutouts. The blades were not riveted to the hub at all, but were an integral part of the hub.
There was a materials lab where I worked. The lab analyzed the broken blade surfaces and pronounced fatigue failure as the cause.
Moss replaced the fan belt, radiator, and fan (with another identical one). After installing the second fan on 5 March 1996 (34,105 miles), I drove the car to 14 February 1997 (35,660 miles). At that point, I received a bulletin from Moss that instructed anyone who bought such a fan remove it immediately and return it to them for replacement with a different type of fan plus a gift certificate (for $100, as I recall). I did this (and noted that the second fan had paint chips in all the semicircular cutouts, indicating flexing of the blades and probable future failure). This time Moss sent a multi-blade metal fan with stainless steel blades and of a riveted construction. I installed that fan, but it had an objectionable whine. I replaced it because of the noise with a Texas Kooler plastic fan, which remains on the car.
The fan that failed on my car was similar, but not identical to the one Bill Young shows in his photo, which has riveted blades and no semicircular cutouts.
B
Bill Young
An interesting story on fans Steve. We have a couple of club members still using those Moss fans that were recalled. We will be changing them.
Does anybody have a picture of a fan blade penetrating the shroud or bonnet?
sjahc.com
BJ8Healeys
I saw a blade protruding from the bonnet on a car at the AHCA Conclave in Winston-Salem in 2005, but did not take a photo of it, unfortunately.
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D Fan Blade Austin Healey 11
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B Fan Blade Shroud Austin Healey 5
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
jfarris For Sale TR6 8-Blade Fan & Mounting Hardware Triumph Classifieds 0
Steve P. six blade plastic fan bolts? Spridgets 6
T 'best' fan blade configuration? Spridgets 2
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
S Funny Fan Blade Length Austin Healey 10
T TR2/3/3A TR3A Fan Blade Conversion Triumph 30
J MKII Fan Blade Color Austin Healey 6
A Fan blade Austin Healey 20
T TR4/4A TRF Fan 8 blade in 4a Triumph 10
go_inbroke Fan Blade Triumph 7
H xj6 fan blade Jaguar 10
healeyboz fan blade? Spridgets 9
drooartz 6-blade fan on 948 Spridgets 10
G 13 blade plastic fan Triumph 13
T Broken Fan Blade[s] Triumph 10
G Six Blade Metal Fan on my 67 Midget Spridgets 2
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
