Fan Belt Shortage?
bob hughes
Editor Read
I have some good news and I have some bad news
What you have discovered is right, well least ways as far as AH Spares are concerned, they can not get
them any more.
However, SC Parts have had some 17mm wide units in but it is a limited supply.
Both companies offer a 3/8 inch conversion kit for lots of drinking vouchers and of course that will mean that you could then fit the harmonic damper on the end of the crank for even more drinking vouchers.
:cheers:
PAUL161
We have 12 of the standard belts in stock and 20 of the cogged style for 100-4. I will ask our purchasing department to check with our suppliers to be sure they will continue to be available.
Shawn
Shawn, will you be getting in cogged belts for the T series? PJ
Editor_Reid
Editor_Reid
Platinum
Thanks Shawn, although my friend was specifically interested in the concours-correct 3/4-inch belt for his 100M. Have any of those?
ShawnC_at_Moss
Sorry for the late reply. I keep getting logged out of the forum and when I post and ask to be emailed when a subsequent post is made rarely works.
Reid, as far as I can tell our 021-066 is the original type belt. We buy from AH Spare part number CHT137 and have plenty on hand. On a subsequent note AH Spares has plenty of the original style in stock.
PJ, the cogged belt for the T series is also on the shelf and in good supply under part number 434-125.
Shawn
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
T BJ8 Fan Belt Change Austin Healey 7
B TR6 TR6 Fan Belt Triumph 4
G TR2/3/3A Fan belt Triumph 6
M TR4/4A Narrow belt conversion with thermo fan. Triumph 0
J TR2/3/3A Changing fan belt. Triumph 9
C MK1 3000 fan belt Austin Healey 1
J TR2/3/3A Local fan belt supplier. Triumph 7
T TR2/3/3A What length fan belt for TR3A with GM 7127 alternator? Triumph 4
JPSmit Fan Belt Question Spridgets 9
F TR6 76 TR-6 Fan Belt Replacement Triumph 5
J TR 4 original fan belt size Triumph 20
K TR2/3/3A TR3 Generator/ Fan Belt Issue Triumph 12
drooartz Fan belt for alternator on 1275? Spridgets 4
M Fan belt replacement Triumph 25
T Pulley - fan belt - oh my... Triumph 8
Rhodyspit75 Fan belt replacement Triumph 3
S bj8 fan belt Austin Healey 17
TonyPanchot Eating fan belt Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Fan Belt Question Triumph 18
S TR2/3/3A 61 tr3 fan belt alignment Triumph 6
C FAN BELT SIZE? Austin Healey 3
W Fan belt diffferences? Spridgets 2
drooartz Fan belt dimensions? Spridgets 9
drooartz Fan belt/pulley question Spridgets 7
T TR6 One more Rock Auto quirk - TR6 fan belt Triumph 5
66healey fan belt on 66 bj8 Austin Healey 3
M New Fan Belt Squeaks Triumph 15
Tinkerman TR2/3/3A TR 3A Fan belt and Crank pully question. Triumph 9
B Fan Belt Triumph 7
davidk TR6 Changing TR-6 Fan Belt - Need Help! Triumph 11
MGTF1250Dave Fan Belt Sizing in UK Triumph 3
JeffR Concours fan belt Austin Healey 1
T Aligning crossbar after fan belt change - argh! Triumph 8
jerrybny TR6 TR6 Fan Belt Deflection Triumph 2
M TR6 TR6 Alternator/Fan Belt Issues Triumph 9
M TR4/4A TR4 Fan Belt Triumph 13
TR4 Fan Belt Pulley Removal????? Triumph 6
S squeaky fan belt Triumph 3
Patton How tight should the fan belt be? Austin Healey 8
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
