Mark_Gibson
Factory /Dealer Installed/PO Heater Stuff [TR-2]
As I'm taking my car apart, I know that it has the optional heater installed with all the associated plumbing, etc. What is puzzling me are the other gadgets in this car that all have heater hose connections. One of them is a blower motor assisted heater, complete witha small core, that was hooked up to the defroster outlets. It has an intake under the bonnet, and the heater assembly hangs down above the passenger footwell. Attached is a picture, can anyone tell me where this was installed? It looks like some sort of kit that was made for the car, but it doesn't show anything about it in the service manual.
I also have another gadget that has 2 heater hose connections and mounts above the transmission tunnel. It has a lever actuated valve that sends water to the other heater, or you can shut it off. It also has some sort of thermocouple tube that mounts under the drivers side footwell area, so it's some sort of thermostatic contol. The picture of this is attached also. It was made in Columbus, OH, so I'm sure it wasn't a factory installed option! It also looks like someone cut out the firewall (messy job) to install this item. Any help on there two gadgets wouyld be greatly appreciated.
Thanks,
Thanks,
