T
Tinster
I have completed the rehab of my rocker arm assembly and the following data is supplied to go with the video. The engine starts easily with these settings. What do other eyes and ears tell me I need to do before I install the valve cover and
drive this beast? Valves were gapped at .012 to help get
engine running. Re-gapped to spec .010" All opinions appreciated.
Thanks as always.............dale(tinster)
So I have timing 10* advance at 850 RPM
New Autolite 63 Plugs gapped .030"
Jeff's Points gapped .012"
Valves gapped .010"
New Borg Warner Select coil at 40,000V
New Moss rotor
New 7mm Pep Boys plug wires
Valves gapped .010"
New Moss rotor
