TR2/3/3A Exhaust Systems
Skidude
I have a 59 TR3 with a one muffler exhaust system. It's stainless steel and in great shape - but, it's a little too loud for me.
For this year's winter project - I'm considering putting in a 2 muffler stainless steel exhaust system.
The question is - which system have you had the best luck with (quality and installation) - the Tourist Trophy system sold be Moss Motors - or the Falcon system sold by The Roadster Factory - or, another brand available elsewhere?
The cost difference is so small - it doesn't matter between Moss and TRF. I want the better and easier to install correctly system.
Graham H
I got my exhaust from Bastuck & co Germany makes the right noise and pleasant on the ear.
Graham
Graham H
I don't know how to do sound or video , I will ask one of my boys if they can do it
Graham
CJD
Do you need the entire exhaust or can you just add the resonator on to your current one?
S
Skidude
My understanding is I have to replace the entire exhaust system - no way to insert the front resonator on it's own.
CJD
As shown in the pic above, the main muffler is forward of the axle, and the resonator is behind. Without the resonator you just have a straight pipe behind the axle. If you purchase a resonator any muffler shop can install it pretty easily by replacing the straight pipe with the resonator + tailpipe. I would just think that would be much cheaper than replacing the entire system when you only want to add the resonator??
TomMull
I normally strive for originality but I started using the Thrush cherry bomb back in the 1960's and it is still available today. They are about $30 and you can pick them up at most auto stores. The rest of the system is stock plain steel. Not for everybody of course. (I happened to have the fancy stainless clamp hanging around.)
Also note that if the pipe hits the cruciform on the way through, as they often do, it will greatly amplify the noise.
Tom
tinman58
I just recently redid my exhaust on my TR3. I used a magna flow muffler with 2"in and 2" out. Also a 12" glasspac, The sound is great and the horse power went up dramatically. I knew there would be some power increase but was really suprised on the extra HP. I am not worried about originality, especially with the supercharger!
steveg
Did you have the supercharger all along and the muffler added "kick in the pants" horsepower? Or did you add the supercharger at the same time as the muffler?
If Triumphs normally have straight-through mufflers, it's unlikely any other straight-through muffler would add noticeable power.
The added supercharger comment was kind of a ringer. :eek:
tinman58
I have had the supercharger for many years. The exhaust that was on the TR3 was the pace Monza exhaust from Moss.
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Simmo MGB Exhaust Systems MG 10
BOBBYR Exhaust systems ? Austin Healey 2
T Swapping exhaust systems on a Sprite Spridgets 3
TonyPanchot Exhaust systems/ mods Triumph 15
R E Type Exhaust systems Jaguar 2
G SS Exhaust Systems - BELL vs. FALCON Austin Healey 13
R exhaust systems MG 1
tahoe healey stainless exhaust systems Austin Healey 3
7 Exhaust systems MG 17
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
