Exhaust leaks
AUSMHLY
What performance problems could exhaust leaks cause?
I did a leak test today by attaching a leaf blower to the tail pipes and spraying soapy water to the entire muffler system. More leaks than I thought.
I'd appreciate advise of how to repair them and with what products without having to replace the pieces, if possible.
1) Both leak at the manifold. Brass nuts are tight. Hopefully new gaskets will fix.
2) Leaks in the middle of the flex area of the down pipe. Can sealing muffler tape be used?
3) Leaks under the clamps at the front and rear where the pipes join the muffler.
4) Leaks, pin size, where the pipe is welded to the muffler.
Any recommendations of what products to use?
>>> New gaskets with high-temp sealant: https://www.aircraftspruce.com/cata...MIyLO7_qTh5QIVD8ZkCh13owxSEAQYBSABEgLSzfD_BwE
>>> Tape probably won't work; weld up the leaky area (if you can find it)
>>> High temp sealant (see above)
>>> Grind the area a little, then JB Weld
Note all 'fixes'--except the new gaskets with sealant--are probably temporary.
steveg
re #3) Versachem works well if you clean the joints first. 1000*F continuous, 1500 intermittent:
These types of clamps work best - you really have to tighten them to prevent leaks. (Examples aren't necessarily the right sizes):
I should have mentioned that both the downpipe and exhaust manifold flanges are notorious for being warped (the downpipe flanges appear to come pre-warped from the manufacturer these days). Since you have to take the downpipes off anyway, be sure to flat file the flanges as best you can; no amount of gaskets and goop will seal a warped joint for long.
Steve, that looks like good stuff, but it has a couple really negative reviews; I guess it worked for you? I'm still searching for the blue stuff Edd China always used on exhaust joints; if it's good enough for Edd ...
HealeyRick
The interwebs seems to agree this is the stuff Edd uses: https://mossmotors.com/hylomar-exha...MIrqbm05zi5QIVBL3ICh1K8AItEAkYASABEgK8nvD_BwE
I think if I was going to remove the downpipes to do the gaskets, I'd bite the bullet and replace the downpipes entirely. That metal in the flex joints can be thin and resist efforts at repairing.
Michael Oritt
No one addressed the initial question: "What performance problems could exhaust leaks cause?"
steveg
...Steve, that looks like good stuff, but it has a couple really negative reviews; I guess it worked for you? I'm still searching for the blue stuff Edd China always used on exhaust joints; if it's good enough for Edd ...
Bob - I'm still looking for the perfect goop. Maybe one of these is better.
Google searched for "best exhaust sealant":
One thing about the Versachem is it comes in a larger tube than the Permatex.
AUSMHLY
AUSMHLY
Would having exhaust leaks affect carburetor tuning?
Might air leaks affect this reading?
Leaks will not affect power or gas mileage?
Seems I've never been able to get the mileage other BJ8 owners say they get.
It sure would be swell if low mileage was as simple as addressing exhaust leaks.
AUSMHLY
AUSMHLY
Ok, not the first guy to ever ask this question, so feel free to school me.
If the flanges are warped, would having a thicker gasket help? Being they come in only one thickness, double the gaskets?
Thanks, Rick. Hylomar makes a paste that might be good for plugging holes:
http://hylomar.com/hylomar-product-range/exhaust-products/
Keoke
HI TH
I use plain pld RTV on mine works a charm.
As a matter of fact the flex jont on one of my pipes got damaged somehow , so I simply sealed that hole with RTV.
You will have a problem dismantling it later but a torch will ease the pain.
Morris Exhaust leaks Spridgets 11
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
