moremonkey
Last night I was finally ready to fire up the Healey so I could run the car up through the gears (in the garage, on jack stands) to see if I had oil pressure in the overdrive. Because it was about 6 degrees outside and the car was backed into the garage anyway, I rigged up a foil dryer vent to the tailpipe and ran it through a piece of plywood I cut to fit in the garage window. Very clever.
But in third gear there was so much exhaust pressure coming out the tailpipe it blew a hole in the vent hose, and in the 30 seconds it took me to realize what was happening and shut the car off, I smogged up the garage, set off the smoke detector (which set off all the smoke detectors in the house and freaked out the kids and the cat) and gave me a nice little headache.
The question for the forum (beyond the general "isn't this pretty amusing") is: what setups do you use to run a car in the garage with the doors closed? I don't like leaving the garage door up a little and running a vent out that way when the car is parked in bow first because I always get exhaust leaking back into the garage under the door.
Clearly dryer vent is not robust enough to do the job. There must be a simple, obvious way to rig something reliable and safe.
Incidentally, I was getting about 425psi at the overdrive pressure gauge. But I don't think the car was going into overdrive (there was a lot of catastrophe going on all at once by the time I hit third gear so I am not really sure. And I can't run the car to find out for sure until I have a new exhaust management system). Am I correct in assuming that with the gauge screwed into the fitting on the OD, the car will not shift into OD?
Hi Guest!
--------:highly_amused:
