On to stage two of my "repair the rolling wreck" adventure.
1960 Mercedes-Benz 190b. Four cylinder, gasoline, 4 speed manual. Very basic car.
The "engine won't start" problem was resolved when I discovered the ignition switch was faulty. Bypassed the ignition (hot wired the car) and engine starts and idles fine.
But the engine won't rev up. Slowly open throttle, nothing happens. No rpm change. Hold throttle open, engine dies.
Carb works fine; fuel system, ignition, timing, valves, points, etc. all test good.
Compression test shows 160, 160, 162, 160 psi. Spec is 128-142.
I test drove the car before purchase, back in October. Drove fine, but noisy (rusted out) muffler. One week after I drove it, the owner had the muffler replaced (Midas). Two weeks later I bought the car and had it shipped to me.
Exhaust system partially blocked? Any way to test without trying to pull the gol'dern manifold off? There's no vacuum test port on the manifold.
Thanks.
Tom
Thanks.
Tom
