Excessive Fuel Pressure - how do I stop the leak?
Hegg
So I've been taking apart a few things so that I can get my carbs off and do a rebuild on 'em. Of course I had to remove the fuel line from the fuel input rail to the carburetors. That of course leaked all over. So I plugged it up with a rag/towel and thought that would do it. Nope, it kept leaking.
Needless to say, I've tried many things over the past few days and it just leaks past all of them. I finally took of the rubber line that goes into the fuel pump and yikes!
fuel is POURING out of that line. It just doesn't stop. It pours out at quite a high rate (enough pressure that it's squirting UP out of the tube about 1 inch). I finally got it stopped (I think) by cutting the end of the hose off, putting in a large bolt, then clamping down on it with one of the hose clamps.
So the question is -- is this normal? It seems like an aweful lot of fuel pressure to be coming up the line BEFORE the fuel pump. One of the reasons I was going to rebiuld my carbs is because they seem to be leaking really bad (fuel drips off the bottom). Surely a gasket could help that, but if I'm having that much fuel pressure constantly pushing against my carbs when the car is off, what's to stop it from leaking all over?
Assuming this isn't normal, where do I start checking for problems? There's not anything between the fuel tank and the fuel pump, is there? It's gonna be a bugger of a time getting that hose back on the fuel pump once I'm done...
Thanks in advance! Lots of expertise here!
steve99
Im thinkin that your fuel line is below the level of fuel in your tank and your just seeing gravity in action... The only other thing I can think of that would do it is a pressurized tank, (faulty venting system). Good luck.
Hegg
Hegg
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by steve99:
Im thinkin that your fuel line is below the level of fuel in your tank and your just seeing gravity in action... The only other thing I can think of that would do it is a pressurized tank, (faulty venting system). Good luck.<hr></blockquote>
Now that I think of it, the tank is rather full, so it could just be the weight of the fuel causing the pressure. I removed the gas cap to make sure any pressure in the top was relieved, but that just seemed to make the fuel come out faster.
I think you're probably right though -- the fuel line would be below the fuel level in the tank, so it's probably just that.
Thanks!
Steven
I had the same thing happen when i changed a fuel filter on my TR6. I solved the problem by using a pair of vise grips as a clamp on the rubber fuel line. Just make sure to use a good supply of masking tape so the teeth of the vice grips don't eat your rubber fuel line hose, and clamp it just enough to stop the flow. There's probably a better tool to use, but the vise grips were all I had at the time, and they worked, so why pay more?
philman
I inserted a bolt in the fuel line and clamped with a hose clamp.
Mark Beiser
On the TR7, the entire fuel tank is higher than the level of the line that goes into the fuel pump. If your tank is full, the level of the fuel is higher than the top of the engine.
Steven
the words you don't want to hear under a TR6 when you're trying to clamp the fuel line is....."Hey, its dark down here, does anyone have a match?"
F Excessive Brake Pedal Travel Austin Healey 3
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
LAW75 Bonnet Excessive Sway Austin Healey 6
D TR2/3/3A Excessive cranking before it starts. Triumph 47
R TR4/4A Excessive body rattles Triumph 5
Tinkerman TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play. Triumph 2
H excessive wheel bearing shims? Austin Healey 11
M Bn2 excessive oil pressure Austin Healey 4
R TR4/4A TR4A Excessive oil consumption-PCV valve or ?? Triumph 9
RJS Excessive Brake Dust? Triumph 7
Johnny What does "excessive brake fluid pressure" mean? Austin Healey 21
J Excessive exhaust smoke Austin Healey 12
R Excessive oil pressure problem Austin Healey 17
V TR5/TR250 excessive oil usage on tr250 Triumph 6
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
