A big thanks to everyone for their help and suggestions on this issue.
I have found that the main problem was the outer of the choke cable was sliding into the knob assembly so pulling the choke only shortened the outer not the inner. This did nothing to move the jets.
I attempted to crimp the knob assembly to the outer having first applied locktite to the outer. This morning I thought about it and found a steel rope thimble that fitted the cable outer and crimped that as a stop.
Then reset the front carb taking up the preload as SP53 suggested then adjusted the linkage so the rear carb had it's preload applied.
It takes a lot of effort to pull the choke but it started right up.
I notice the outer has slipped some in the carb clamp. Have to check that in the morning.
Thanks again. I hope this has been put to bed.
David
David
