Car was restored about 6 years ago. About 5K miles since. Too much wear on front outer edges. Is this likely too much + camber or could it be toe in. Rears are wearing okay. How can camber be adjusted? Two types of mod's available that I found: 1. remove top shock plate and reweld an adjustment plate, or 2. cut slit in shock tower below top plate, remove welded nuts, and install a slider plate. 1967 BJ8
Hi Guest!
