BoneIdle
Well, the GT made the 6 hour trip from Mechanicsville, IA to lovely Winona Lake, IN back in late March. Prior to the trip, the car had been down for about a year while I figured out what to do about replacing the gas tank.
I ( and yes, I mean "I") replaced the gas tank, then the fuel pump ( it was leaking and I didn't have the nerve to drive 300+ miles that way), removed and disassembled the carbs (SU HIF4 X2, reinstalled, etc.
I had no problem starting the car, I adjusted the mixture and the idle - the thing was running like a top. I drove about 20 miles the night before the trip and the engine was running smoothly.
On starting the road trip, I drove approximately 15 miles before I began hearing and feeling small pops in around the resonator. This wasn't a big deal, but about the time I reached the middle of Illinois, as soon as I decelerated on an exit ramp, the engine was misfiring. I could keep it running,but there was no power - it almost felt and sounded like a fouled plug.
There were no symptoms ,such as increased engine temp, decreased oil pressure, and oddly enough, no exhaust smoke ( that I could see).
The problem seemed to resolve itself after the car was switched off ( e.g. at a service station), or when it was being driven at a steady speed ( 60 mph and corresponding RPMs).
So, this occurred pretty much every time, I'd slow down.
As soon as I could get the unpacking under control, I began working on the GT again. Once again I pulled the carbs ( this was yesterday). Everything was relatively clean, so I reinstalled, readjusted, and drove up to the convenience store to fill the tank. No problem.
I decided that I was hungry and there was a McDonald's about 1/4 mile away, so I drove there. No problem.
I was sitting in the drive thru line for about 5 minutes. Big problem. The misfiring began. I could barely keep the car running.
After a couple of minutes of revving the engine, I was able to drive away, but it was still as if more than one plug was fouling.
As I headed reached home ( about a 2 mile trip), I noticed that the engine was running normally again.
I've about given up on the idea that this problem has anything to do with fuel delivery.
Does anyone have suggestions? BTW, this is a standard ignition system, not Electronic.
