Little tidbit,
ENVIRO-SAFE is an "ENVIRONMENTALLY SAFE" organic,non-toxic, non-ozone depleting
hydrocarbon compound. ENVIRO-SAFE is a hydrocarbon refrigerant which has been endorsed
by Greenpeace and is in full compliance with the UN Montreal Protocol.Like most organic
materials ENVIRO-SAFE is flammable, but its ignition temperature is 1585ยบF at both 5 psi and 0
psi(which is better than the DuPont R-134a's ignition temperature of 368ยบF at 5 psi and 1411ยบF
at 0 psi). Nevertheless, a pine odor has been added to the product so that any leak in a
refrigeration system can be readily detected. To locate the precise origin of aleak, it is
recommended that a hydrocarbon detector be utilized. Most mid and higher priced
conventional leak detectors will detect hydrocarbon refrigerants. In the alternative, either soap
bubbles or ENVIRO-SAFE DYE CHARGE can be used. ENVIRO-SAFE DYE CHARGE is both
visually detectable and responsive to black light. In a safety study, the prestigious Arthur D.
Little scientists concluded that hydrocarbon refrigerants pose no significant increased risk or
hazard over freon. (copy of report available at cost of US$5.00)
Now, it's in the tractor and is supposed to put out cooler air, but in my tractor the cooling air temp is about the same as the R-134a. Haven't measured it with a meter. PJ
