Hi: I have to attach an aluminum collar 1” wide with an ID of either 2 3/4” or 2 11/16” to a steel pulley hub (Morgan TR3 engine) of 2.705”. The collar has two set screws.
1) Which JB Weld, Loctite or similar epoxy product will give the best bond between the aluminum and steel?
2) Are we better to get the larger ID collar and have a gap of 45 thousandths? Or the smaller ID and sand the inside of the collar to allow it to fit over the shaft with minimal gap? ie. What is the ideal gap between the aluminum and steel to be welded by the job weld? Thanks
Hi Guest!
