Wedge Engine
Bob Claffie
I was told years ago that there was a direct relationship between the Tr7 engine and one of the Saab engines. IIRC it was the Saab 99 , possibly 900. Considering both engines have somewhat of a history of head gasket/ warping problems I'd like to put this to bed once and for all. As I am in the market for a TR7 "project" I'd like to know what to be wary of. Thanks, bob
TR3driver
Great Pumpkin - R.I.P
In simple terms, if it is not running, or has been overheated, even "running when parked"; plan on changing the engine.
As I understand it, the SAAB 99 motor started out very similar to the TR7 version, but they made a lot of changes to improve reliability and so on. Might be a good candidate for a swap, if you can find one.
https://en.wikipedia.org/wiki/Saab_B_engine
glemon
Not only can the head Warp (my brother has had two TR7s for a total of about 30 years with no such problems, so it doesn't always happen) but the heads are notoriously difficult to remove, as the studs not only corrode but are angled, making for some fun with language when you try to take one off.
There are still used parts sitting in garages and shops, and if you get lucky you can pick up a used motor fairly cheaply.
Lastly, people like to put V-6s, or Rover V8s in them too.
TomMull
I had 1975 TR7 as my only driver for quite a few years. I bought it cheap when it was a few years old because it leaked antifreeze along the head gasket line when sitting overnight. I re-torqued the head, leak stopped and no other issues for as long as I owned it, at least 50k miles. Could be I just got lucky.
Randall's warning above is sound but not limited to the TR7, at least in my experience.
I think the TR7 is a neat little classic that can be enjoyed at minimal cost and decent reliability, even with the original engine.
Tom
Tybalt
The earliest Saab 99 models used a variation of the 1.7L and then 1.85L engine fitted to the Dolomite and TR7. I don't think any were ever fitted with the twin cam version fitted to the Dolomite Sprint, definitely none for the US market, maybe some other markets. After a few years, Saab changed over to their own engine. Most of the nominal bits were interchangable between the two engine variants used by Triumph and Saab but some specific bits were not. I remember sometimes having to hit up a local Saab dealer and Triumph dealer to make up comprehensive set of valve adjustment shims to work on either as an example.
TR3driver
I could be mistaken, but I don't think you will find any usable tr7 heads just "laying around". Last time I saw one for sale, it was priced somewhere north of $1500. And that was over 10 years ago.
FWIW, the fine folks at ISOA have developed a special tool just to remove the head. IIRC it's free to use, but you have to be a club member, and pay a substantial deposit. Doing it without the custom tool is apt to ruin both head and cylinder block beyond economical repair.
Darrell_Walker
That would the the TWOA, unless ISOA also has one.
https://www.triumphwedgeowners.org/tr7-head-honcho.html
In any case, a TWOA membership is well worth the cost for any Wedge owner.
TR3driver
Whoops! My mistake, I'm sure Darrell is right.
Bob Claffie
Bob Claffie
Thank you one and all. You (collectively) have probably saved me from going down a dark and unforgiving trail. I will look elsewhere for an outlet to exercise my urge to restore some ratty LBC. Bob C
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
