Hi
I seem to have a problem with the valve guides / seals. Yesterday I dumped some oil into the engine, and went to start it. The #4 cyl almost immediately fouled its plug, and the smoke coming out of the tailpipe was something fierce.
When I had the engine apart, the machinist took a look at the valves /guides and said they were fine (not to loose) of course the normal Triumph design doesn't have valve seals. These are probably tight enough for a more "conventional
design with seals. There are valve seals on my engine, but they are all riding on the top of the valve not connected to the valve guide. Whatever is supposed to hold it at the bottom obviously isn't doing the job. Right now they sort of look like little umbrellas about 1 cm above the valve guide. Clearly not doing much good. When I put it all together, the valve seals were pushed onto the guide, but the first time the valves were pushed in the guides slid up and stayed.
Where can I get decent seals that will fit and stay in place?
Kind of annoyed those plugs haven't been in the engine for more than 20 minutes of running time.
