Csarneson
I bought a dowel bolt from Aircraft Supply. $8 delivered.
I am now trying to mate my engine and transmission. I have used the clutch alignment tool and am comfortable that the splines are properly aligned. My engine is on a mobile engine stand. I've strapped my transmission to my rolling floor jack. There is some wiggle with the angle here so I can actually adjust it a little.
Theoretically I should be able to lift the transmission into a rough alignment and then lift the tail while pushing them together. The only video I've seen on this has been on the smaller 4-cylinder engines or lighter transmissions without overdrive. My transmission/overdrive is HEAVY! I can lift it, but don't want to kill my back doing this.
What voodoo have people used?
Chris
Chris
Hi Guest!
