Engine/transmission installation help please.
YOu can bend the drive shaft if you install it with the engine and trans. best to install it after.
Ya that yoke going to flop all over the place and you will not be able to get it into the trans UNLESS you stuff a rag around the joints to hold it straight. On the first test drive it will fly out. then you can just fish it out of the tunnel
