Working on a TR3B for a friend and have got it running after its long rest.
Went through the carbs and did a seal kit. Adjusted the jets to all the way up then down 10 flats as a starting point. I think the rear carb is a little rich at the moment.
Replaced everything on the ignition side. Coil, condenser, points and plug leads.
Replaced the fuel line from the tank to the fuel pump.
Checked and reset the timing to 8 degreed BTDC static. It was 8 degrees ATDC. Ran but not well.
Replaced exhaust down pipe.,
When I accelerate from idle slowly the motor shakes all the way to about 3000 rpm. If I accelerate quicker it seems to stop shaking sooner.
The TR has the Monza Free flow exhaust system on it so it sounds very different to my TR3A
What am I missing.
David
What am I missing.
David
