anthony7777
now that the leaves are falling from the trees[at least here in connecticut]it won't be long befor we have snow,ya i know bummer,in the down time im plannig to rebuilt the transmissin i.e sinkros,lay shaft,seals,clutch etc,i will also be replacing the rear eng.seal,years ago we would replace these with a common chevy seal with great success,i wish i could remember wich one it was because they never leaked again!i recently purchased a new seal that consists of an aluminum flange that must be properly aligned,drilled and tapped[into the rear of the engine block]this item can be viewed on the 'moss'sight. has anyone used this type of seal?if so are they any good?what if any are the pitfalls of the install etc,are there better ones available.input much appreciated.anthony7777-1963 A.H.3000 MK.II /ubbthreads/images/graemlins/hammer.gif
