I have a very good spare set of used valve lifters. I don't see any hint of cupping.
While replacing my rings, however (long story), I noticed that two of my current lifters in use have some abrasions and chipping on the underside. One sort of bad. What causes that? I did run low on oil once.
Those lifters (the ones now in my car) all have a little oiling hole in the side. But if I replace the two chipped lifters with ones from my spare kit, they won't match since my spare set has no hole in the side of the lifter for oil. Other than that, they appear almost identical. Bright shiny steel.
Do I dare mix and match like this and put two of my spares in there, or do I just need a new set (and what about weight disparities)?
thx
thx
