DougF
I installed an Isky Z-19 cam. Valves are properly adjusted, taking care with break in, used Brad Penn Break In Oil for the first 30 minutes and changed it along with new filter to Brad Penn 20w-50 Racing "Green" Oil with a can of Comp Cam Break In Additive. I'm getting more valve clatter than I should, enough that I can hear it when I pass houses and walls that are near the street. Number 3 cylinder seemed to be lacking some power which was greatly improved with a different plug wire. The motor runs strong.
I'm using chrome moly push rods that Richard Good estimated should fit the head height.
I'll be measuring lift when I can borrow a dial indicator.
Any thoughts in the mean time?
I really don't want to be buying/swapping cams and I really don't want to use my old S2 cam. 3500-6000 rpm power range is higher than I want.
