lclark0624
You may have missed my question under the string "good news. bad news? so I'll ask again here.
In reading the prior string, you saw that the engine broke and there's something loose and there is no oil pressure. Dry compression checks show low readings for 1, 2, and 4 cyl's (see prior string). Wet readings show the same with much higher readings. since there is need of tear down I might as well to more of an overhaul since the compression readings are so weak. Someone said the parts should run about $400- $500 for the parts if I do it myself.
My question is, what are we talking about if a reputable shop does it? $1,500, $2,000, $2,500, or ________.
I'd like to have an idea going in. I'm talking a normal rebuild, not a soup up. If the shop is way out in left field, I'd like to know that in advance.
Surely someone had had this done by a shop receintly. Would you share your experiences.
Hi Guest!
