if 18V's started in '72, it sounds possible that your car had a 18GUH engine swapped in at some point.
I know it's not ~always~ correct, because it relies on it's users to provide the information, but this is what Wikipedia says about the B-Series Engine(
B-Seires Engines):
18 = displacement
G = MG
U = central gear change (other letters were A=Automatic, N=column shift(?), O=Overdrive)
H = High Compression (alternatively L=low compression).
From the '73 model year on, the numbering scheme was simplified to just 18V; 18=displacement, V=vertical layout (front engine rear drive).
Thinking more about your engine and the model year of your car, it might be possible that you're car was registered as a '73 and still have an earlier 18G engine as the correct engine, if the manufacture date is before August '72.
Then again, I've read many posts on these forums where there have been criss-crossing of parts (from the manufacturer) during those 'cross over' years. So, it may be possible that you fall into one of those categories too.
