mrsprite
OK.....I have a '59 Austin-Healey Sprite with a Datsun A15 engine that has been in the car for 20 years now (I've owned the car for 5). It was running just fine, but the clutch was slipping (has been for a year now), so I decided to do a clutch job and replace a leaky rear main seal. I've had this engine out 3 or 4 times previous to this and have swapped cams, etc, so I am familiar with it. All I did was remove the engine, pull the pan, remove the old seal, install a new seal, install pan (w/new gasket, of course!) and install a new clutch. That's it....nothing else. When I got it all back together I had a noise. It sounded like valves rattling so I readjusted the valves (even though I never touched them or even removed the valve cover). Still there. Friends suggested I may have spun a bearing......against my better judgment I pulled off the pan and removed the main & rod caps. Bearings look pretty darn good for a 20 year old engine rebuild.....nothing wrong at all. I put it all back together again and, of course, the noise is still present.
I am curious of anyone can help identify this noise. I even went so far as to remove the valve springs to see if I broke a valve guide or had a busted spring......everything I can see checks out. I also removed the belt to make sure it wasn't the water pump or alternator.....still there. My only thoughts are:
- a loose valve seat (unlikely, but possible)
- bad lifter(s) and/or camshaft
- rocker arm assembly binding up (I did remove all the rockers from the shaft and inspected everything....all looked good)
I'm at my wits end. I wish I just left in the slipping clutch! My next move is to pop off the cylinder head and have a look. Any thoughts before I do this would be great.
Listen to the video and give me your opinions/ideas.
Thanks.
https://www.youtube.com/watch?v=9J-IlIKCZoA
Thanks.
