I just pulled the water pump. Though it was not leaking, and though it's barely one year old, the bearings are shot. It squeaks and binds on every revolution. I'm hoping that was my knocking sound, though I was hearing a ceramic knock from that area, not a squeak. Perhaps under load and RPMs, it turns to a knock? Back to the rocker arm, Randall, are you saying that oil flows through the middle of that arm? Is there a maintenance routine for that? Anything else to check under that valve cover? I may also change the oil and use synthetic in case I've got a sticking lifter like Geo suggested. I did check the distributor weights, but just by eyeballing with magnifiers. The springs were attached and all looked good. If it's not this water pump or something under the valve cover, I'll pull that again and get right down into it.
