TR2/3/3A Engine Mounts TR3A
Frank_D
I am having my engine re-built over the winter and have taken the opportunity to do some tidying in the engine bay. I decided to replace the old engine mounts while I had the block out. It was easy to remove the old ones and I did note the orientation of the one on the passenger side where the bolt coming through the rubber was in the lower end of the block like the picture below. I did not make a mental note of the other mount positioning when I removed it thinking it would be the same. I have received the new engine mounts and installed them a few days ago. However, I could see the outline of the original mounts and the shims in the paint on the face of the flange where the mounts attach. By examoing the marks on the flange on the drivers side, it appears that the mount was positioned reversed to the mount on the passenger side with the bolt in the upper position. Does this make sense? Thanks for any advice on what is a simple issue. Frank D............ TS42756LO
AFAIK, they both should have the bolt on the upper side. But the frames were not always perfectly accurate, so the factory sometimes used shims to line things up. Perhaps some previous mechanic found that it would line up better (without the shims) if one of the mounts was inverted.
Thanks Randall. I will have a look at alignment issues when the block is dropped in again and take it from there.
Frank
