Engine Machining Up-date
Brosky
Engine Machining Update
Just so everyone doesn't think that 2Wrench is having all of the fun, I'll be ready to start soon. I was at the shop today to drop of the oil pan and some shims for behind the crank gear and I got a few shots of my parts.
The head is done. Shaved, cc'd, and all new valves and springs in and set up, along with a nice three angle valve job. Valve guides are cut and new seals are in. Bob made shims for under the new double springs and machined the old collars to fit the new full length spring to prevent it from walking, without causing any coil bind. Proper spring height and pressures are set.
The crankshaft has been cut .010" under and balanced. It will be polished a bit more next week.
The pistons are all matched and balanced.
All new ARP rod bolts and fully reconditioned rods.
There was some surface rust on the manifold side of the block that I didn't want to deal with after assembly, so I asked to put it back in the tank and here it is, ready for machining over the weekend.
If all goes well, the cam bearing journals will be bored out, the deck was be cut and squared, the line boring for the mains and cylinder boring for .030" oversize pistons will happen by Monday. Engine short block assembly will take place and it will be ready by Weds or Thursday to go back to Erik's for final assembly.
For those who wondered (TR6 Bill) about how the engine came out without also removing the trans, Erik says he does it all the time. Taking the trans tunnel cover off makes it easier, but he does it routinely without doing so.
T
Tinster
Re: Engine Machining Update
Awesome Paul !!
What are those many pointed fasteners called?
And how do you tighten them?
d
Brosky
Brosky
Dale,
Those are the ARP bolts and that 12 point head is the same as the nuts on my ARP head bolt studs and crankshaft bolts.
It's their trademark, so to speak.
Many have had trouble with the original TR6 bolts after a rebuild, so out they go and in comes the new.
martx-5
Tinster said:
Awesome Paul !!
d
ARP like to use those twelve pointed nuts. I got the same with my ARP head stud set for the TR3. A regular twelve point socket fits over them. Of course, I had to go out and buy one, as I have very few twelve point sockets! :crazy:
Platinum
I ~LOVE~ shiny-new engine bits!!!
My heart's all aflutter. :laugh:
Don Elliott
Paul - You have a weight difference of over 7 grams for the con-rods. Why don't you grind a bit off the heavier ones (or have your engine re-builder do it) so they will all be equal. This is a simple way to improve the balance of the engine. When my neighbour re-assembled the engine for my TR3A back in 1988, he did this. Also he matched the weights for the pistons. That's all the balancing we did and for the next 75,000 miles or so, my 4-cylinder engine would idle at 300 RPM without stalling. For the last 24,000 miles it idles a bit higher and a bit irregularly, but I think that has to do with the carbs and I suspect maybe specifically the brass rods for the butterflies in my SU carbs could be worn and letting air get in to alter the richness ratio at idle. But it runs fine and is still very loose and smooth on acceleration.
DNK
Don, I think they are going to do that. I think that is the pre balance weights
Brosky
Brosky
Don,
It's still coming along. That is part of the plan. Every part that turns in or on the engine will be balanced. As you see in the picture, the crank was the first on the balancer. The aluminum flywheel, pressure plate, damper, water pump & pulley, etc. all need to be finished.
I may have misstated the rod conditions above when I said they were fully reconditioned. I showed the pics of the bolts and resizing, but he's not completely done yet.
The little note stuck between the rods in here says to match to the piston pins and then balance.
G
Paul, ARP offers three levels of connecting rod bolts, kinda like <span style="font-style: italic">good, better, and best</span>. Which did you choose? They are priced accordingly. When I pull my rod bearings, I think I will just go with the <span style="font-style: italic">good.</span>
Platinum
If ya lubed the contact surfaces use the lower (ARP) recommendations.
Brosky
Brosky
I'm judging by the price that these are the best. Torque settings will apply with the ARP lube specs, not the 30W oil, since we're using ARP lube for the build.
Yeah, it's too darn confusing, but the machinist builds mega HP engines using those ARP specs along with their Moly Lube, so I gotta trust his judgment.
And Bill, he did have to do some machining to the rods to install these. It just wasn't a drop in deal. Sorry, but I don't have the exact details, but I think that he took pics of it for me as part of the documentation package.
Platinum
The shoulder'd bolts would need a relief cut at the rod ends is my WAG.
Brosky
Brosky
I'm sorry that I don't have the details, but I forgot to ask today. I just didn't want anyone to think it was just a simple swap.
ARP should be able to tell you exactly what they need. I do expect that my aluminum flywheel will need some tweaking for the ARP bolts that I got for that as well.
TheSearcherMan
What cam are you going to use, and what compression ratio? What will you set the timing at, and what will total advance be? Whose lifters did you use? Thanks
Number_6
That looks pretty awesome Paul. I was over at the Erik's shop Thursday morning to talk some more about what I want done with my TR3. He said that might send my engine out to the same shop where your having you work done. Your engines looking great! Maybe the next time I stop at Erik's shop I'll get a chance to see that beautiful engine being put into your car. :thumbsup:
T General Tech Machining TR3A Engine liners... Triumph 6
P Engine Machining Cost Triumph 20
Brosky Engine block machining and partial assembly Triumph 8
2wrench Engine machining Latest Triumph 4
2wrench Engine machining in progress Triumph 18
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
