tony barnhill said:I'm not damaging THIS engine compartment!!
My plan for tomorrow (if everything works out) is to mate the engine/trans & remove the grille.Rik said:Tony,
If you haven't already done so, go ahead and connect the engine and tranny so we can install it as a unit. Car should be on jack stands (all four corners)to allow me to get underneath to help guide the unit in when needed and connect the driveshaft, etc.
I will try and get to your place semi-early Tuesday.
Rik
jlaird said:Shaft should be unbolted from the rear end. The front universal taped straight and the whole thing inserted from the rear after the engine and tranny are in.
Works for me all by my self.
jhorton3 said:I think I installed mine with the starter on, but the clutch slave was off. The clutch slave is a pain to install afterward, but it'll be one less thing to hang on something in the engine bay on the way in.
