Engine fan - '69 E-Type
jjbunn
With the ignition key turned to on, the front fan in the engine compartment of my '69 E-Type is powered up. Is this normal? I have some extra wiring in that area that I haven't traced yet, but appears to be connected with a switch under the dash (shown below, with blue wires):
(the switch doesn't apparently do anything, and has no volts on either side of it). I'm wondering whether this is an addition a PO made so that the engine fan could be overridden? Any ideas? (Also, am I missing some sort of under-dash cover that would conceal all these wires?)
Thanks!
jessebogan
The fan is supposed to operate off of a temp switch, in the lower hose I think. However, as etypes are known to run warm on occasion (usually due to something needing to be fixed) people set them up so that the fans run all the time. Some patient work w/ the wiring diagram should sort the fans out. At least you know they work... There should be a "hardura" (cardboard) cover under the dash. They are available as repro parts, and can be vexing to fit... Easy enough, but finding the original screw holes will test your vocabulary.
Grantura_MKI
There should only be two fans that are fitted to your shroud that "suck" air through the matrix. They are controlled via the Otter switch located on the top header tank of your radiator. After warm up, with the ignition "on", the fans should be functioning.
This must explain all of the extra wiring that I enquired about in a previous post. Seems that the keeper before you added an extra fan at the front and the extra wiring. I would be extra sure that the front fan is wired with a fuse and relay...fans draw tonnes of current. From your pictures, you still have the square cased fan motors...they maybe tired. The re-placement units are not the same shape, so do not bin them...you may want them at a later date. With the Otter switch, both fan motors, relays, etc. all working properly, you will not need the fan at the front.
As mentioned above, PO's can add/change wiring to fans. When I built my 68, I added parallel wiring circuit to the fans so I could control them manually if I wanted. You don't need fans on the highway moving. I also like a idiot light to tell me when the fans are on.
Marv
Platinum
We've wired up a number of S-2 and S-3 cars with a switch in the dash to manually control that pair of fans, relay'd and fused. Unfortunately we no longer can find the switch with an indicator light built in. Somebody likely still has such a thing. A very close match with the originals.
jjbunn
jjbunn
Thanks all.
It was a poor wiring setup: they'd been routed in such a way that they'd been crimped by the bonnet, the insulation had failed and shorted against the frame rails. The fuse was blown. Here's a photo of the damaged area:
I removed the wires up to near the fan, plus the fuse, and pulled out the switch. I don't know if the fan works or not, but I'm going to leave it unconnected for now.
Trouble is, after that, the twin fans at the front still come on when the ignition is turned on.
Platinum
"Triple Redundant Fan" circuitry!!!! BRILLIANT! :jester:
Grantura_MKI
Yep! Rip out all of the shyte! Love the "scotch" clip. Is that after the engine is warmed? Is the Otter switch still fitted? Please, Julian purchase a "Bentley" manual. It will make all of the wiring, etc seem like a day at the park.
Grantura_MKI
Sorry, just noticed in your piccy that the relay's are present on the front splash panel. Check them. I have several here if you need them.
Platinum
ScotchLoks... Take a piece of aluminum, pierce copper wiring with it, then "insulate" it with a plastic cover... Can you say "electrolysis"?!?!
EeEEEEeeEEEEEEEeeeee!!!!
jjbunn
jjbunn
Yup, ordered the Bentley manual a couple of days ago - not here yet.
I wondered what those relays are! There seem to be a couple of ground wires hanging off nearby them. I'll check the relays on the bench.
Thanks all.
Grantura_MKI
Julian, you have the only E ever produced that does not need earths...so it seems? Geez, you are going to have fun sorting the electrics out. You might find that once all earths have been cleaned, most of the electical problems will be solved?
jjbunn
jjbunn
Perhaps a PO had heard the term "virtual earth", and decided to take it literally?
Yes, the electrics are proving interesting. Fortunately electrics are one thing I know a bit about. Fuse 8 was blowing ... traced that (I think) to the indicator/turn signal stalk. There's a wire earth braid just hanging loose from that! Also, the stalk seems very flimsy.
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
N Engine Fan question? Triumph 12
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
S TR2/3/3A Tr3 engine fan Triumph 6
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
