TR2/3/3A Engine does not shut off right away. Why?
Momikey
Hello,
So I know this is a common problem with lots of cars but what is the cause?
When I turn car off engine runs a little bit then shuts off.
Is this a timing thing? Or more to do with carb adjustments? Or what?
Thanks.
bobhustead
Excess heat or excess compression (carbonized combustion chambers) can cause the engine to diesel (i.e., ignite fuel without spark). Excess idle speed can exacerbate the problem. Higher octane can ameliorate. When the switch is off, timing is no longer relevant (no spark). If mistiming is enough to contribute to excess heat it could contribute to dieseling. Fuel mixture on the rich side will help cool the combustion chambers, lean to "hotten" chambers. Less likely, wrong plugs can store high heat and set off compressed fuel.
M
Momikey
Thank You Sir.
Deleted member 8987
The only thing I would ask is does it just run on a bit (smoothly...well, as smoothly as a TRactor can run) or jumping around and coughing like a 1912 Marmon?
If it runs just like it did before you turned the key off.....seen that a lot over the years.
If you have an aftermarket cooling fan on the radiator...and not relay controlled via the distributor wire off the ignition switch...and the fan is running...you turn off the key, the fan then becomes a generator, having energy in the spinning blade, and the car will keep right on running as it was for a specific period of time before the voltage output of that fan gets low enough there is insufficient spark to keep going.
Keoke
Very good info "TDC"---:encouragement:
DougME
A quick "fix" is revving the engine prior to turning off the key. Then immediately turn off the key while holding the throttle open. The mass of cold air sucked in then cools down all the hot parts and the engine will stop without dieseling.
Doug
'64 TR-3B
sp53
Built up carbon is glowing red hot and igniting the fuel causing the motor to run on. I have seen them go 20 to 30 seconds
Frank_D
I have had this problem for some time as well. Rebuilt engine, slightly hotter cam, 89 mm pistons and rebuilt carbs. I do what Doug suggested and it works every time. I think my issue is compression and not getting 94 octane on a regular basis. Try the rev and open throttle; it works for me.
Frank D.........
sp53
I was taught that if you accelerate the engine and shut the key off to stop pre-ignition the unburned gasoline would go into the oil and contaminate the oil thus the oil needed to be change frequently. Mover, this unburned fuel would wash out the oil rings and wear the cylinders out sooner.
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
drooartz How much does the engine move? Spridgets 10
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
K Switch to Synthetic Oil...Does Engine need to be.. Triumph 2
2wrench What does it mean to "Blue Print" and engine to U Triumph 17
D Engine FOUND!!!........WTN does happy dance. MG 48
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
