philman
I am dismantling my brother's mg engine to rebuild while he is overseas in Iraq. Do I need to remove the rear plate from the block to pull out the crank and cam shafts? Also, what will be the correct color to paint when assembled? He has a single weber downdraft, I am trying to talk him into twin HS6's or the nifty Kehin set-up from PRI (?) down in southern oregon.
