Glen_B
What I saw and heard from the video is a motor not getting enough (or any) oil to the rockers. You said you had recently had the head off. If the oil hole in the block/head/head gasket is blocked, or if you diddled with the rocker shaft.... Only one rocker tower has a hole to guide the oil from the top of the head to the rockers. If you disassembled the rocker assembly and reassembled incorrectly, the oil supply rocker tower may now be in the wrong position. You would have great oil pressure, find little oil puddled on the top of the head after running the motor and the rockers will get louder and louder with every minute of operation. Sound familiar?
Glen Byrns
Glen Byrns
