Trevor Jessie
It's hard for me to tell on the video. Can you isolate it using the broom handle/screw driver in the ear test?
Forgive me, I don't know what this is. Please elaborate so I can explain to my neighbours that I'm perfectly fine.Trevor Jessie said:Can you isolate it using the broom handle/screw driver in the ear test?
He could slip the belt off and fire it up for a sec and see if the noise goes away, but not for long with no water flow.Morris said:I had a top end oiling problem that sounded very much like your "Youtube."
I also had a 240z that had an idler pulley on the water pump belt with a bad bearing that would make all kinds of racket like that. Could you have a bad bearing in your alternator or water pump? I have also heard water pumps making a lot of racket like that when they start to fall apart.
