Engine Cart
MCS
Hello,
Anybody have pictures of the engine carts they made. I just pulled the motor out of my newly acquired BJ7, just a little bit heavier then my sprite motor. Tried to move it on the floor, does not slide on card board. I have a meg welder and have decided to build a rolling engine frame. Any pictures or drawings would be appreciated.
Thanks Phil
Just a thought Phil, are you going to rebuild the engine then place it on an engine stand and you will not need the cart--Fwiw--Keoke
Phil -
Harbor Freight $20.00 for a moving dolley. I've used it the past 4 times I've pulled my motor with no problem, just leveled it with a couple 2"x4" blocks.
The motor will get rebuilt late this year, so for now I would like it to roll it around safely, as it does take up allot of room
thanks for the picture Dougie, I may go to Princess Auto and look for something similar today
thanks Phil
Handmade but works. Will hold tran/OD and motor using the existing engine brackets.
I made a simple rectangular frame and welded casters to each corner. I used the stock engine mounts, and made a bracket to bolt them to. Later, a friend helped me wire the motor, and I mounted the tach, water/oil gauge and ignition key in a simple "dash" so I can go out in the garage and start it up. I also got a two into one exhaust adapter from Magnaflow and used an old Honda muffler so I don't scare the neighbors too bad.
Digger
I'm with Keoke......just mount it to an engine stand and roll it around!
thanks for the pictures digger
Nice to run it before installing
Phil
