saabmp3
So I'm stuck in upstate NY (for the last time) winter and jealous of all the work Droo and Jack are getting done.
As some of you probably don't remember, last summer I got the chance to replace my rear diff (from a 4.22 to a 3.9), clean up the rear axle and do some minor engine work. When I put her back in storage at the end of the summer I was battling low oil pressure and had just found a dog leg 5 speed datsun transmission to put in there.
I had a blast working on the rear axle. The only downfall was that I was trying to get the job done as quickly as possible so I could get the car back on the road.
Over the winter I started thinking about the low oil pressure issue and the 5 speed install and possible ways to combine them. I think I've decided that I'm going to run my current 1275 with some band aids (aka heavy oil) and my 4 speed while I build a second engine.
I'd like to get in the neighborhood of 80 HP, stay fairly original (so this locks in the 1275 block) and stay with carbs.
So, first off. Where do I start? What are some good books to pick up on the subject? Write ups, etc. I have at least 2 more months of snow and I'm stuck inside.
Second, for people who have built somewhat amped engines, how feasible does this look? I'm starting this plan out with a supercharger in mind (hopefully the purist don't have issue with this).
Third, again for current builders, can you recommend a good starting point. Decisions I need to make and how to pick out parts. I'd like part recommendations too, BUT I'm a firm believer in understanding what I'm doing and then deciding from that knowledge. So far I've only decided on a 1275 block. The bore is going to depend in a large part on the current condition of what I can find.
Finally, where should I look for cheap parts? Old engines, carbs, etc.
Great, I'm looking forward to this.
Ben
Ben
