Hi All -
Finally got my BT7 back from the Paint and Body shop after a years worth of work. Have been driving it around locally and noticed a problem that I had when I sent it in for paint. Maybe someone has an idea. I did a search but didn't come up with anything so I'll ask here.
The car runs great when it is first started, can run all day with no problems at all. The problem starts when I stop somewhere for anywhere between 10-45 minutes. After stopping the car starts right back up and runs well with the exception that it will stutter occasionally, especially when under load. It will act like this for about 10 mins, then it runs great with no problem.
The only thing I can think of is that the gas in bowls / lines is becoming superheated while the engine has stopped and something in the compression/fire cycle is suffering as a result. Once the hot gas is consumed and replaced with cooler gas from the tank, it runs fine. That doesn't make sense to me though.
Any thoughts?
Some specifics:
Rebuilt engine <5000 miles
Fresh Plugs < 500 miles
Mixture seems good with the plugs a very light grey.
New Coil ( Had the problem with both old coil and new coil)
Fuel Filter in place between tank and pump. ( I'm replacing the tank this weekend so I'll check that while in there)
Thanks for the help,
Jim
Any thoughts?
Some specifics:
Jim
