VelodromeRacer
Well, As you saw on the other post, I swapped out the 948 for the hot 1275 motor. As per a British car....I am having to make a few bits and other changes to get the engine to be "plug n play". I have a track test day this next Sunday. I had to order a few AN fittings and adapters..they won't be here till Tuesday.
So, I know others have said that I need to break in the engine by running it between 1500 and 2000 rpm for 20 minutes...I assumw this is without a load and parked? I can do that here at home before the track day...should I do that, then change the oil and then go to my track day and drive her like I stole her?
Here is another picture.... Photo1
