Engine Bay 99% Complete
Joe:
Here's a photo of the one I've done, mild steel as the stand-offs. May drill them at the tops near the tube and put in #6 machine screws/washers/nuts for a bit more structural rigidity. Not sure yet, but it couldn't hurt.
I like the good Dr's solution, but looks like he's running a weber and doesn't need a heat shield. So that might work for you too Joe with your DCOE. Here are two closer shots, it's the big bolt on the manifold that is the issue. I had originally planned to clamp it to one of the smaller bolts in the rear. I'm not sure it will vibrate against anything, it sits about 1/4" proud of that big bolt in teh front. I'll keep playing with it, I'm sure...
PS - thanks Bruce!
This isn't a very good pic, but you can see where my throttle cable loops down right next to the rear of the valve cover. I'll either have to reroute the throttle...or route the heater pipe just above and outboard of that throttle linkage.
John...what about taking the big bolt out & milling it thinner?
I've a SawzAll I'll loan out /ubbthreads/images/graemlins/wink.gif
Yes John; a Weber on mine, with a Rube Goldberg bellcrank accel linkage arrangement (cable comes in from below). Ho-made, y'see. Used the drawings in the "Special Tuning" manual to approximate it "back inna day." Almost ashamed to have the bonnet up around guys like Tony: he'd laugh 'is arse off while pointin' at it. ;P
Maybe Tony, or I'll see if I could find a plug. I wonder what the size of the threads are... Hmmmm....
My guess is BSP something-or-other. Never had much success finding plugs to fit any pipe or bung hole from "Merry Olde" unless it was ordered as that OE replacement. At least it's listed in Moss & Vickie Brit.
Bruce, that would describe mar car pretty well. Other than some Krylon touch-up work and electrical tape on the 41-year-old wiring harness, it's basically untouched. BUT... it always runs like a champ, or it did until it tore the engine out a while back.
Here's a photo of the outside: CLICK
Here's a photo of the engine bay: CLICK
John, great job, you're almost there and getting there fast. Will you be driving this car or sealing it in a glass bubble for all to admire?
[ QUOTE ]
Bruce, that would describe mar car pretty well. Other than some Krylon touch-up work and electrical tape on the 41-year-old wiring harness, it's basically untouched. BUT... it always runs like a champ, or it did until it tore the engine out a while back.[ QUOTE ]
And that is fine. Just don't ever try selling it saying it is restored./ubbthreads/images/graemlins/grin.gif Car looks great and as long as it runs great that is most important.
Bruce
huh... Bruce, did you just quote yourself inside of a quote from Steve_S?
[ QUOTE ]
[/ QUOTE ]
Oh it will be a driver! What fun is a MG is a glass bubble!? lol!
[ QUOTE ]
huh... Bruce, did you just quote yourself inside of a quote from Steve_S?[ QUOTE ]
I think he did!
[/ QUOTE ]
[/ QUOTE ]
Yes John! The '64 here is a DRIVER! If it looks presentable and runs well, what else could ya want? "Restoration" is for cars with histories or examples that've been "uncompromised." If it's been in service for any time it's been compromised. Make 'em good runners and ENJOY 'em! Putting an MGB through a total restoration and then on a pillow inna livin' room would be a waste of a great car, IMHO.
[ QUOTE ]
[/ QUOTE ]
I didn't. Somehow the forum software did though.
Bruce
Just as a follow up, I got the copper pipe to work! I unbolted all three bolts and with the largest one, I put on a bit of teflon tape and got it to seal with a flat toward the valve cover, that gave me enough room to clamp the pipe in place along the manifold. There is not alot of clearance between the large bolt and the pipe, so I will have to keep an eye on it, to make sure it doesn't rub.
Nice solution, John.
Now stop posting those pix... you're makin' me want to go out and bury my car. /ubbthreads/images/graemlins/cryin.gif
John - is that a washer under that big front bolt or just the manifold itself?
What if you got another manifold that didn't have that big "lump" (for wont of another word)?
Tony,
That is a washer under there. It's a fairly early manifold, tho' I don't know what year. It doesn't have the elbow in the middle like the 70's years.
