You can't even begin to imagine how nervous I am about reassembling this engine - so, with your indulgance I will have lots of questions before I start. Here is the first round.
1. Do you reuse circlips? If not, can I get them at a auto supply store or are they mysterious British?
2. I laid out the studs for the head last night. 6 are 4 /16 inches, 2 are 4 5/8 inches. why are 2 longer & where do they go?
3. When inserting head studs, long thread up or down? and do I use loc tite or anything?
4. Bentley (p 209) talks about reinstalling pistons.
a) Which side of the cylinder is the "thrust side"
b) He advocated oiling the rings but elseware speaks of assembly lube. Can I use assembly lube on everything?
c) Which way are piston connecting rods aligned?
5. Do I need a special tool for installing piston rings on the pistons?
6. Tell me about reamers.
Thanks again y'all - I would be in serious trouble without this board!
