Bruce -
I installed the same set up last winter and ran into the same situation. You need to re-orient the starter. It has an adjustable mounting plate. Just loosen the two allen head screws and rotate the entire starter assembly until everything clears the rails. I found it easier to install the engine and gearbox in the car, then install the starter. This way, you can more readily see which way the starter needs to be rotated.
