ELECTRONIC IGNITION FOR A 3000 ?
CASCADEWILLY
WHO MAKES A QUALITY ELECTRONIC IGNITION FOR A 1960 3000 ? IF ANYONE IS USING ONE THEY HAVE HAD GOOD OR BAD EXPERIENCES WITH, LETS HERE THE STORY ?
WILLY
Keoke
[ QUOTE ]
WILLY
[/ QUOTE ]
Wouldn't get on the road with a Healey without a Pertronix under the bonnet.---Keoke-- /ubbthreads/images/graemlins/hammer.gif
Hangtown Healey
Being on the road with others equiped with Pertronix, if you want one, buy two and keep one in the boot.
If you want more reliablity, get a Crane. 20 years with no problems, but I still keep the points in the boot.
Ed_K
Petronics uses a hall effect transistor as a sensor. It picks up magnetic pulses from the rotating ring that is slid down on the distributor shaft underneath the rotor in place of the points. The only way this can fail is if the hall effect transistor fails. The other brands use a rotating disk with little slots cut into it. The sensor is an LED/photo cell. If enough dirt builds up on the surface of the sensor or if it closes up or changes the " shape " of the slots, you will start having problems. They are both very good ways to elimate the need for points, will last forever in most cases, and will certainly provide a more reliable and evenly shaped pulse to trigger a high voltage spark from the coil than the original set of points. I like the concept of the petronics not ever being able to be bothered by dirt / foreign matter buildup. But since they both work so well, it is just a theroy. You can chose the one you want without much to be concerned about. IMHO .... Almost forgot, the petronics has one failure mode, the hall effect transistor fails. The other has three failure modes, the slots can fill up with dirt, the LED can fail, and the photo cell can fail. I guess that is the real case for using the petronics unit.
Dave Russell
Yoda - R.I.P
Hi Ed,
I agree. Also, I believe that the Hall Effect transducer is also more precise (positionally accurate) than the optical transducers.
As a matter of interest, The early Pertronix units reportedly had some problems with the rotating magnets coming unstuck. They have never really lived down the bad reputation that they gained from earlier problems.
This all being said, the Pertronix is low enough cost that I DO keep a spare in the car. Have not needed it & don't really expect to.
Keoke
Aw Dave, We fixed that magnet problem years ago---Keoke- /ubbthreads/images/graemlins/yesnod.gif- /ubbthreads/images/graemlins/grin.gif
12Many
I had one of the early Pertnoix units fail however the company replaced it for no charge and the new one has been flawless for about 5 years. I also carry points but that is only because my wife was with me when the first unit failed and she will not drive the car without them. /ubbthreads/images/graemlins/patriot.gif
Keoke
12Many,I told you in my response to DR we fixed em up real good years ago.There was a bug in the initial design---Keoke-- /ubbthreads/images/graemlins/laugh.gif
Keoke
[ QUOTE ]
Keoke, were you involved in the Pertronix? If so, I'm impressed.
[/ QUOTE ]
OH ,I just gave em a bit of heck for screwing up.---Keoke /ubbthreads/images/graemlins/laugh.gif
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
O Sprite Petronix Electronic Ignition Spridgets 10
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
R Electronic Ignition Distributor Spridgets 14
D Electronic Ignition for 25D distributors Spridgets 15
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
T Electronic Ignition Issue Austin Healey 6
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
rosalind electronic ignition conversion - advice please? British Motor Corp 3
D Electronic ignition choice[s] Triumph 17
D Rebound straps and electronic ignition MG 2
J Midget 1500 electronic ignition? Spridgets 10
scott_74 Electronic Ignition? Spridgets 15
NardisCNC Electronic Ignition Upgrade Questions... Spridgets 17
C Electronic Ignition Tutorial please? Triumph 20
H electronic ignition systems Austin Healey 11
SCguy Wedge Best electronic ignition for my TR8 Triumph 9
H Plug wires for electronic ignition Austin Healey 18
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
T static timing with electronic ignition? Triumph 10
R Electronic ignition Spridgets 5
AUSMHLY Petronix Electronic Ignition positive ground Austin Healey 10
SherpaPilot Best Electronic Ignition? Triumph 9
vette MGB MGB Electronic Ignition MG 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Yes, another electronic ignition question Spridgets 2
Sarastro Crane electronic ignition installation Spridgets 3
Raymond electronic Ignition MG 20
Atrus Electronic Ignition Comparisons Spridgets 24
JamesWilson Electronic Ignition? Lotus 7
R Electronic ignition Austin Healey 11
tony barnhill NORTON BOYER ELECTRONIC IGNITION WITH COILS &podtr British Motorbikes 4
ChrisS Electronic Ignition Spridgets 5
W Electronic Ignition MG 9
