Not sure where a post like this belongs, so this is just a best guess for passing along some knowledge.
I bought a stainless-steel header for a Bugeye restoration project I am working on. The welds were unfortunately all tinged yellow from the heat generated when they were welded. I researched several methods of cleaning this off and arrived at a process which works quite well, and does not harm the rust resistance properties of SS like some other abrasive or chemical cleaning methods.
Using a 6V 6amp battery charger I attached the positive side to the work piece. I bought a stainless fender washer and made a crude “mop” using some cotton string, then attached that to the negative electrode. I dipped the mop in some dilute phosphoric acid (rust converter) and then touched the mop to the welded discolored area. After a few seconds the yellow discolor dissipated and I wiped it away with a paper towel. I finished with wiping the area down with a baking soda solution to neutralize any remaining acid.
I’m sure the header will discolor from heat over time, but at least it will start out all shiny and pretty! Here's before and after shots of one weld.
