Electrical sleeving
steveg
Has anyone found a source for flexible vinyl electrical sleeving?
I've been faking it with unshrunk shrink tubing and pvc drip line tubing, but am looking for a source for real flexible vinyl sleeving. Not interested in the modern split corrugated stuff.
You might try Grainger they have a broad product line
Thanks Keoke & Lin - Everyone has the high-tech expandable, woven etc. I'm looking for the stuff that looks like thin vinyl tubing but is more flexible than drip tube. This may be it. Will follow up when received:
Okay, now I understand. I got my sleeve - mostly used for the front lights - from British Wiring. They have multiple sizes.
Lin
Received the black vinyl tube today per screenshot above. Don't recommend it as it's more rigid than flexible and tends to buckle when bent.
Have a call into British Wiring to see if their product is more flexible like the OEM sleeving.
Steve, I think you will find the British Wiring product to be flexible. My only complaint is that the larger diameter tubes come flat and it is hard to get rid of the fold crease.
Lin
